Qantas A380 and 747-400 emergency landings at Changi
Originally posted by boing View PostIt's definitely an uncontained engine failure. Saw pics on a website where internal parts of the engine( compressor or turbine disc hub) was found in a house ! It's lucky none of this parts hit anyone as it will be sure (ugly) death being hit by any of these. Most engines only have the fan and first stage compressor sections protected with a kevlar exterior around the casings in case of a bird strike. Not the whole engine.
Foresee an AD or a SI coming up on RR Trent 900 engines and possible maintenance actions. Most likely culprit at this point in time would be fatigue cracks. Seems eerily reminiscent of an UA DC 10 incident in the US some years back.
http://www.perthnow.com.au/gallery-e...864448?page=19
It's really lucky none of this parts pierced the fuel tank as it would have been a potential catastrophe. And as SQDazz mentioned, QF A380s are maintained in house and to LH as well, if I'm not mistaken. So, out goes the outsourcing of the blame as well.
Meanwhile QF has said it will suspend its A380 flights. The SIN-LHR QF 0031 has been cancelled for today, not sure if other A380 flights will be affected.
Let's hope the root cause of the problem will be discovered, problem fixed, and air travel made safer after this incident.
But I wonder how SQ will cope if its 380 fleet had to be grounded ...
Well.. SQ apparently will delay its A380 flights, whatever that means...
http://www.singaporeair.com/saa/Util...up.jsp?msgId=1
Originally posted by boing View PostIt's really lucky none of this parts pierced the fuel tank as it would have been a potential catastrophe.
http://www.pprune.org/rumours-news/4...ml#post6037776
that the hole in the wing meant that one of the engines could not be shutdown (hence why the fire crews were trying to drown the engine with water).
Originally posted by MAN Flyer View PostBeen trying to work out where at Changi the bird is on that shot.
An A380 Qantas flight, QF 32, bound for Sydney, Australia, departed Singapore Changi Airport at 0956 hours today. For technical reasons, the aircraft turned back to Changi and landed safely at 1146 hours.
Changi Airport Group's Airport Emergency Service (AES) responded with six fire vehicles, in accordance with standard operating procedure for such incidents. In response to the pilot's request, checks were conducted on the aircraft by AES. Once the checks were completed, passengers and crew began disembarking from the aircraft at Runway 2. Buses were arranged to ferry them to the airport terminal. Disembarkation of all 469 passengers and crew on board was completed by 1340 hours.
Runway 2, which has remained closed since the landing, will reopen later today. Flights have continued to take off and land at Runway 1 and operations at Changi have, otherwise, not been affected.
Originally posted by FN-GM View PostThis might sound a stupid question but why are the landing gear doors still open?
zvezda, correct me if I'm wrong.
Originally posted by globetrekker84 View PostDefinitely not a stupid question. It's possible that when the engine failed, it might have set the plane in an "emergency mode", where the hydraulics would only be used on flight critical components (such as the surfaces). The landing gear doors are considered non-flight critical.
http://www.youtube.com/watch?v=UJN8Paj8I4g
what's that vapour?(clearly it's a puncture in the fuel tank)
not all the spoilers deployed. quite a clear indication of hydraulic lines being severed.
Originally posted by FN-GM View PostCould the vapour from the fuel dump?
found this picture to show you the difference
credits to the photographerLast edited by Nick C; 5 November 2010, 04:20 AM.
Originally posted by Nick C View Postmore like hydraulic failure leading to a gravity drop.
